Problem with CDripper
  • frankenstein
    • Sep 2009
    Hi!
    Just downloaded dbpower amp and having only one problem with it, any help would be appreciated. The problem is with the CD ripper, it will only rip selected cds. The cds it will not rip load on to the cd ripper, but then the programs it automatically closes the program. Ive tried uninstalling and reinstalling, turning off autoplay with tweak UI and neither worked. A friend of mine has the same program and the cds that dont work on mine work on his and we cant figure out what the problem is.
  • Wayne
    • Aug 2002
    • 1254
    Re: Problem with CDripper
    On your PC can these CDs be played/ripped using Window Media Player? What type of drive are you using, IDE or SATA? What version of windows?
    • frankenstein
      • Sep 2009
      Yes.IDE.Windows XP.
      • Wayne
        • Aug 2002
        • 1254
        If you click on the Options button available to the CD ripper what do you have the communication entry set to?
        • frankenstein
          • Sep 2009
          SCSI pass through(SPT)
            Try changing it to Windows Internal and see if that helps.
            • frankenstein
              • Sep 2009
              It doesn't read the cds at all on windows internal.
