Re-downloading
  • ferraris
    • May 2009
    Re-downloading
    I'm trying to download the registered version however when I get to the dBpoweramp Registration Retrieval page if I click on download it tries to download "getrep.aspx". I'm using Firefox and clicking the link whilst holding down ALT & SHIFT only gives me the option to save the file or use Flashgot or the browser downloader to save the file and I think I need to execute it?
    Can anyone help?
    Simon
    Re: Re-downloading
    Set your browser security levels to default (if you disable scripting etc then that disable the download).
    • ferraris
      • May 2009
      Re: Re-downloading
      My browser seemed to be on the default setting anyway, solved by using a Chrome rather than Firefox.
      Simon
