AccurateRip contradiction?
  • craibuc
    • May 2009
    Before I attempt to rip a new (unripped) CD, usually dbPowerAmp will display a message that reads 'CD in AccurateRip'. However, when each track finishes ripping, the Rip Status column reads 'Not in AccurateRip'. This doesn't always occur, however. Is this a contradiction? Am I missing something?
    In general, if a CD isn't in AccurateRip, is the best practice to do a Secure Rip?
    Thanks for your time.
    Re: AccurateRip contradiction?
    On one of the files >> Right Click >> Edit Tag and if there is an AccurateRip Disc ID post here please.
    • craibuc
      • May 2009
      I check the Options; the Ripping Method was set to 'Defective by Design'. I switched it to 'Burst' and the issue seems to have been resolved.
      What is the significance of a 'Accurate' rip status, but a red-colored CRC value?
      • Teknojnky
        • Dec 2006
        • 323
        red crc means that the crc does not match the last time you ripped that track.
        if you rip the same track/cd twice in a row, the crc should be green, its just a useful visual confirmation if you rip more than once (like if track was insecure or not in accurate rip).
        Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
        Want a random mode based on track and artist relationships?
        [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
        [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
