Problem with ID Tags
  • jorgjean
    • Apr 2009
    • 11
    If I use the CD Ripper, the Tags will be found from the Internet. However after ripping, under Windows explorer, the visibility of the tags is very inconsistent. Example: theTrack Name will not be visible or the tracks are not numbered. Has anybody else problems with this ?
    Re: Problem with ID Tags
    Using which audio format?
    • jorgjean
      • Apr 2009
      • 11
      I am ripping CD's into wma lossless and mp3 or converting from wma lossless into mp3.
        If you right click >> edit tag on one of the affected files, are the tags correct?
        • jorgjean
          • Apr 2009
          • 11
          Well, I have just ripped another CD. WMA lossless all tags taken correctly. MP3: Some song titles missing, some Genre missing, wrong numbering, Some Years missing. If I right click at this stage the info that is not visible in the windows explorer (XP V3) is also not in the properties. I then complete the missing info in the properties. If I then copy the MP3 files into another folder, some of the titles dissapear again, but this time only in the explorer view. In the properties they are included. I then have to retype the info in again and save in order to see the info in the explorer......
          Strange?
            Select 'Edit Tag' as it will be dBpoweramp showing the files within.
            • jorgjean
              • Apr 2009
              • 11
              That is not really the solution as I want to have the overview in the windows explorer in the respective columns Title, Album....... It seems that Poweramp is not fully compatible with the Windows Explorer and the Windows Tags??
                The other way around is true, Windows has poor compatibility with the mp3 standards out there...
