Meta Review: Color blind issues
  • Mark_H
    • Jan 2009
    Noob here. Please be gentle :komisch9:
    Exploring dBpoweramp and struggling with the Meta Review colors. Because of my color blindness I find it very difficult to easily spot which tag sources are conflicting. Is there a way to change the default colors? Or if not, could the devs please choose something more obviously different - ie black and green or even use italics? Anything to help out their color blind audience.
    Many thanks,
    Mark
  • bhoar
    • Sep 2006
    • 1173
    Re: Meta Review: Color blind issues
    I concur, that's a good idea. It might also be worth reviewing some of the pull-down menus elsewhere in the apps for similar issues.
    -brendan
    • Porcus
      • Feb 2007
      • 792
      Good idea, I think, no matter what colours are used.
