24-bit\vista 64-bit\creative SB?
  • savagcl
    • Aug 2004
    • 439
    System: Vista 64-bit, SP1
    Definately NOT a dBpoweramp problem but i need some
    help.
    1've gone through 2 creative sound cards so far. Looking for 1
    that will play/record 24-bit sound tracks.
    When i try to play a 24-bit wav track (5.1 speakers), that i made with dBpoweramp (12 or 13.1) creative says it don't
    recognize the file format. Problem is, if i re-record the
    track from its MP3 file, it still will not recognize the file format....
    Both cards were installed ok and the updates were applied from creative website (their recommended critical updates)
    only.
    Anyone experienced similar problems with vista and
    creative sound cards??
    thanks,
    savagcl
