newly purchased
  • neroon
    newly purchased
    just purchased the "dbpoweramp" for a new computer,I have installed it at least 3 times but when I go to convert files all I get are error messages to the tune of my registration has expired any help would be great thanks in advance
    Re: newly purchased
    What are you converting from and to? if you look in dBpoweramp Configuration does it say it is registered? What is the exact expiry message shown?
    • neroon
      Re: newly purchased
      I am trying to convert OGG files to wav files.I add the files that need to be converted ,select the files to be converted to wav, everything seems to be fine until then I press the convert button the program seeme to work then it asks me if its ok to overwrite the files I press ok then a message pops up saying that my trial has expired,which I don't understand because I just bought it.I did try a free trial before purchasing the program but I thought that it was uninstalled when I installed the version that was purchased.Any help would be great.
        Re: newly purchased
        Try uninstalling, reboot windows and reinstall.
        Also be sure you are using dBpoweramp, because normally Ogg >> Wav would never show an expired message unless converting to wav-mp3.
