Monkeys audio problem!
  • prolekult
    • Oct 2008
    Hi, i am new to the forum! Downloaded the lastest version yesterday and all the latest codecs and upgraded to reference. Ripped a cd this morning using Mp3 lame with no problems and file plays in db player. I then tried to rip the same CD using the monkeys lossles codec, File converted no problem but when i go to the destination and try and open it in the player it says that it does not recognize and would i like to open with ....list of programms! or go to the internet to find a programme to associate file with.
    I have tried 3 times with the same result... when i check the ID tags on the file everything is there! Can anyone help?
    Keith
    • 46229
    Re: Monkeys audio problem!
    The audio player (dAP) uses older codecs to Music Converter, so you have to install dAP first with codecs from 'legacy codec central' in a different folder to music converter.
      • prolekult
        • Oct 2008
        Thanks for the quick replys
