upgrading from reference r12 to r13
  • celticwarrior
    • Oct 2008
    In order to upgrde to reference r13 (I have the registerted installer), how do I proceed? Install r13 without unistalling r12? Then unistalling r12? please explain.
  • Thg6276
    • Aug 2008
    • 182
    Re: upgrading from reference r12 to r13
    http://forum.dbpoweramp.com/showthread.php?t=12483
    • celticwarrior
      • Oct 2008
      Thanks. I suppose you refer to this answer:
      "Upgrading from r12 to r13:
      The recommended procedure is to install the latest version, trial or registered, and uninstall the existing version. Your codecs and settings will not be affected."...
      Great, but the installer menu requires you to decide if you uninstall or not r12 ... Now, precisely because of the quote above, I am not shure of what to do: to select "NOT TO " unistall and unsintall r12 manually later, or to select the "UNISTALL" option when prompted by the installer menu...
      Please advise. Thanks!!
        Uninstall r12 then install r13. I edited the linked-to post for sake of clarity.
