dbpoweramp & cygwin
  • pierrep
    • Oct 2008
    • 11
    dbpoweramp & cygwin
    Hello,
    i can't to use dbpoweramp with cygwin in command line on Windows 2003.
    I explain :
    this command is good in cygwin :
    Code:
    coreconverter.exe -infile="myfile.wma" -outfile="outfile.wav" -convert_to="Wave"
    so i can encode myfile.
    but i tried with a space in source ("my file.wma"):
    Code:
    coreconverter.exe -infile="my file.wma" -outfile="outfile.wav" -convert_to="Wave"
    and dbpoweramp find only source="my" ! so it CAN'T encode
    Have you the same problem ?
    Thanks a lot.
    Pierre
    Re: dbpoweramp & cygwin
    something is removing the space or replacing it with a ", you can switch on Music Converter debug (dBpoweramp Configuration) and see the exact command line passed to coreconveter.exe
    • pierrep
      • Oct 2008
      • 11
      ok for inpput or outputfile put it was just a test with space
      The problem is for "convert_to" with mp3 for example !
      Code:
        $ /cygdrive/c/Program\ Files/Illustrate/dBpoweramp/CoreConverter.exe -infile="c
      :\symphonie.wma" -outfile="c:\outfile.mp3" -convert_to="mp3 (Lame)" -V 2
      dBpoweramp Music Converter           (C) 2008 Illustrate Ltd
      Encoding: mp3
      Audio Source: c:\symphonie.wma
      Audio Destination: c:\outfile.mp3
       0%-----------25%-----------50%-----------75%-----------100%
       Error: Unable to load encoder 'mp3'.  [dBCoreConverter::dBCoreConverter]
      Conversion Failed.
      Code:
      :\symphonie.wma" -outfile="c:\outfile.mp3" -convert_to="mp3"\(Lame\)" -V 2"
      Encoding: mp3(Lame)
       Error: Unable to load encoder 'mp3(Lame)'.  [dBCoreConverter::dBCoreConverter]
      Conversion Failed.
      there are a real problem with space.
      it should be something like mp3_(Lame) or mp3_Lame without "()" special character
      any solution for this problem ?
      I tried a lot of syntaxes and never find the solution.
      • pierrep
        • Oct 2008
        • 11
        so i find a solution but it not very usefull (many changes if many plugins and difficult to update !)
        i tried with mp3 lame
        my goal : using "mp3_(Lame)" in command line instead "mp3 (Lame)"
        So my command line is :
        Code:
        :\symphonie.wma" -outfile="c:\outfile.mp3" -convert_to="mp3_(Lame)" -V 2
        in your install path C:\Program Files\Illustrate\dBpoweramp\encoder
        change :
        mp3 (Lame).dll -> mp3_(Lame).dll
        (mp3 (Lame).ico -> mp3_(Lame).ico)
        RESULT :
        Code:
        Encoding: mp3_(Lame)
        Writing ID Tags: Done
        Conversion completed in 23,5 seconds x10 realtime encoding
