accurate & driver
  • felisten
    • Aug 2008
    accurate & driver
    This is what i understand:
    The offset values are based on known cd drivers and music cd's. If i put a music cd, but my driver is not registered in accurate rip, i can not get the offset and related data for EAC.
    thx a lot. Your help will be appreciated.
    Re: accurate & driver
    You need to give the program some "key discs" that it can use to configure. Just put in some of the more-popular pressed (store-bought) CDs you have until it offers to configure. It will say it is configured or ask for 3 more discs that give matching offsets to configure.
    • felisten
      • Aug 2008
      thx mr. ltdata.
      i am using original music cd's of course, and i think accuraterip is working along with freeDB, the problem is i can not see the pop up window:
      How can i see this window?
        • 46228
        Using the latest version of EAC? you might have to ask on their forum as there are a bunch of settings in EAC which can disable accuraterip (mainly gap related.
