Stop working !!! R12.4
  • lanntm
    • Jun 2008
    I downloaded R12.4 a week ago, everything worked well (I wanted to convert all audio files (as m4a, rm, wmv ...) to mp3 in C #). But sometimes it did more, I had to reinstall it and it worked! ... and then the problem back ... for a week I have to reinstall 4 times, it loses time (delete a registry, app data ...). Do you know this problem? How to solve it? Help me please! Thank you!
    I use XP Pro SP2!
    Re: Stop working !!! R12.4
    What do you mean by it stopped working? What stopped, encoding or ripping?
    Try uninstalling dMC, running this: http://forum.dbpoweramp.com/showthread.php?t=13285, then rebooting and reinstalling dMC.
    • lanntm
      • Jun 2008
      it means I can not convert my audio files to mp3, this is my code:
      DMCSCRIPTINGLib.Converter dMC = new DMCSCRIPTINGLib.ConverterClass ();
      dMC.Convert (audio_src, audio_des, "mp3 (Blade)", "-b = 256", "LogConvertAudio.txt");
      when I put a breakpoint here, it does nothing, it passes very very quickly, there is no output file (normally it takes few second here and creates a file mp3). I have not any error, any log.
      ya, i tried it! when i did it, the problem went out but then, it could come back when i restart my PC.
      So, maybe the informations of registry are not saved when i restart PC?
      Thanks!
      (sorry for my english)
      • Wayne
        • Aug 2002
        • 1254
        What is "mp3 (Blade)"?
          Check you have a registered 'Reference' license which is required for scripting.
            mp3 (Blade) was never released for dMC r12, are you using the old r11.5 codec?
            • lanntm
              • Jun 2008
              sorry, it was Lame
              I downloaded dMC + all codecs 2 weeks ago from dbpoweramp.com so i think it was 12.4. My problem is: sometimes dMC (scripting) works, sometimes not, so its not problem of codec, I think.
              I found a better solution for my project ('cause its a commercial project, i need a stable software), anyway thanks for your help!
              :smile2:
