Edit ID Tag missing in Explorer
  • jaklithn
    • Mar 2008
    • 9
    When registering version 12.4 of Music Converter I lost the shell integration of "Edit ID Tag" and "Convert to" that I had in the test version.
    But "Pop-up information" and "Explorer columns" are working.
    I checked the configuration and all these options are checked.
    I changed the association in Explorer from iTunes to MusicConverter.exe but it made no difference.
    Any suggestions?
    Re: Edit ID Tag missing in Explorer
    Uninstall dBpoweramp, reboot windows and reinstall.
    • jaklithn
      • Mar 2008
      • 9
      It worked.
      • Dr. Oviri
        • Mar 2008
        • 9
        I have noticed an error in my Mp3.
        When I add an image using ID-Tag Editor all the images (if present) disappear.
        Besides he is not recognized Artist image...
        However it is a good software :komisch12
          If you click View, do the images show up?
          • Dr. Oviri
            • Mar 2008
            • 9
            Yes, but when I try to add a new Image all images disappear; only the last added by the program is available.
              You are saying, if you have 5 images and you add 1 more, then only 1 image is shown? What originally added those 5 images?
              • Dr. Oviri
                • Mar 2008
                • 9
                Yes. I've also tried to add images in a Mp3 without image with your program; only the last image is available... there's a bug? :cry:
                Usually I work with my program to do this but he work only with 5 image type:
                • Front
                  Back
                  Artist
                  Band
                  Logo
                  Just tried adding the tags from dBpoweramp (5 above and then one more, all ok, non-disapeared), then I tried creating 5 tags in tag&rename, added the 6th in dbpoweramp again no problems, also all the names correctly listed. Perhaps the program used to write the art is not writing it correctly?
                  • Dr. Oviri
                    • Mar 2008
                    • 9
                    No, it work fine Spoon. :komisch12
                    I've tried to add images with dBpoweramp in a Mp3 without images and the error persist. Only the last added image are visible.
                    I wanna try your program in Vista too...
                    • Dr. Oviri
                      • Mar 2008
                      • 9
                      To confirm I've installed dBpoweramp in Vista.
                      After added various image with the program I've opened the file with an Hex Editor; only one tag APIC founded in file... then, for me, there's a bug.
                        Try R13 (beta section of this forum), it is the version I am using and it can add 6 album arts.
                        • Dr. Oviri
                          • Mar 2008
                          • 9
                          Thanx Spoon!
                          Now can work with 14 images :komisch9:
                          • Dr. Oviri
                            • Mar 2008
                            • 9
                            Another question for Spoon:
                            why I can't edit Unsynced Lyrics (USLT) in my files Mp3 with dBPowerAmp? :cry:
                              We do not currently support lyrics.
