AAC or LAME MP3 for iPod?
  • Paul_B
    • Jul 2006
    • 28
    I did a search of the forums and can't find an explanation for which format to use with my iPod Touch.
    I rip all my CDs to FLAC and tag appropriately. The FLAC files are used with my Squeezebox and played over my Hi-Fi. However, I also want a sub-set of my music collection available to my iPod where space is the major concern and I am happy to loose some music quality.
    Question I am asking myself is should I transcode my collection to MP3 using lame or would it be better as AAC? Currently I use LAME VBR at 160bps average. The level of quality is more than adequate for my iPod.
    I don't really know anything about AAC but as it is a newer codec would I achieve the same level of quality as above, with LAME VBR MP3, but a small file size?
    Paul
    Re: AAC or LAME MP3 for iPod?
    Most people say that AAC will give you the same quality as an mp3 file at a slightly smaller bitrate or a better quality file at the same bitrate.
      At 160 Kbps mp3 and aac will be very similar.
      • Paul_B
        • Jul 2006
        • 28
        Spoon,
        That is what I found. Used DBPoweramp to convert FLAC to MP3 (VBR 160bps, DBPoweramp Default) and then AAC (VBR 150 bps, DBPoweramp Default). The AAC file came out slightly larger than the MP3 file. I guess this may not be fair as the AAC is possible better quality than the MP3. But I am not convinced that I should re-encode all my MP3's to AAC to gain any significant saving in filesize.
        Paul
