Noob Question
  • Etouffee
    • Dec 2007
    Noob Question
    Ok guys I have looked around and tried to find an answer to this but I think my frame of reference is just to simple right now so I need some help getting pointed in the right direction.
    I just installed the free version of the encoder because basily I want to be able to turn CD's into MP3 files and put them on the Ipod for the wife. As you know though Itunes you can just upload the CD's but the files are VERY large.
    Although I am not a dummy :P some of what is being said here is just way over my head without a little hand holding.
    Now the conversion part is pretty easy. The part I am having problems with is getting the CD info such as artist and track. Do you have to put this in on your own or can it pull this from the CD? From some posts I saw it looks like there is some code to do it but on my free version it looks as though this might be disabled?
    Thanks for any help that can be provided or directions I can be pointed in to start trying to figure this out.
    Re: Noob Question
    Some CDs have "CD-Text" written on them but not all do, and not all CD drives read the CD-Text properly or at all. dMC will use AMG, if you have a valid subscription, or it will always use freeDB for free. Click the Meta button, and make sure AMG and FreeDB are checked.
      Re: Noob Question
      The meta button is in CD Ripper, not Music Converter. (sorry your reply are accidently deleted with a spam purge, but I did read it!).
