Secure Ripper?
  • KOF
    • Aug 2007
    • 53
    Secure Ripper?
    I think i have another problem no the secure ripper only "passing 1" and then encode the song,
    I have Windows internal for limited account and with 11.5, it was fine, the secure ripper do 2 passing, there is a change how do i use the cd/dvd driver step of using for limited account it might be a help using the nero wspi for windows, or something else, I dont' think the secure ripper it's working ok,
    BTW: 12.2 FULL/ dell lattidue d610, windows xp professional
    Re: Secure Ripper?
    If the CD is in AccurateRip and your rip matches what is in the database, only one rip is done. If the CD is not in AccurateRip or your rip does not match, then 2 Passes are done, then the secure passes (and ultra-secure, if enabled in Reference) are done. See here for how the secure ripper works: http://www.dbpoweramp.com/secure-ripper.htm
