CD Paranoia?
  • KOF
    • Aug 2007
    • 53
    CD Paranoia?
    Are you guys planning to add CD PARANOIA in the ripper option? because i have an cd that has only 3 scratchs and after using the secure ripper i'm still getting errors(like the song skip at the begining)
    Any ideas/./
    Re: CD Paranoia?
    Did you rip in Secure mode? If you are using Reference, try "Ultra Secure". Also, did dMC say the rip was secure?
      Re: CD Paranoia?
      CD Paranoia is not the best as secure ripping, dBpoweramp and EAC far out perform it.
      • KOF
        • Aug 2007
        • 53
        Re: CD Paranoia?
        Yes, I did it!!
        First I used secure ripper then "Ultra Secure Ripper" and nothing that song still skips when I play it. DMC said "secure" but somethings is wrong. i guess.
        Thanks!!
          Re: CD Paranoia?
          If you preview the CD in the CD ripper window, does it still skip?
          • KOF
            • Aug 2007
            • 53
            Re: CD Paranoia?
            Yes, but only the first song, that's why I use "secure ripper" to correct that error,
            BTW: dbpoweramp 12.2, "Secure Ripper" + Accurate Rip on + Windows internal for limited accounts so i guess for limited account i can't use c2 errors corrections right?
            but, i ripped in my other computer using Ultra secure ripper + c2 on w/out results!
            this is the track: can i send you track, i have not aviliity to send attachment.
              Re: CD Paranoia?
              Correct, limited accounts can't use C2. Note that the Secure Ripper cannot always rip a perfect track off of CDs. Is there any noticeable scratches on the CD that you could buff out with something like a SkipDoctor or something?
