Site Problem - frequent php error
  • Biser
    • Aug 2007
    Warning: Unknown(): php_network_getaddresses: getaddrinfo failed: Name or service not known (is your IPV6 configuration correct? If this error happens all the time, try reconfiguring PHP using --disable-ipv6 option to configure) in /global.php(389) : eval()'d code on line 3
    Warning: Unknown(http://www.dbpoweramp.com/header2.html): failed to open stream: Connection timed out in /global.php(389) : eval()'d code on line 3
    Fatal error: (null)(): Failed opening required 'http://www.dbpoweramp.com/header2.html' (include_path='.:/usr/share/pear') in /home/httpd/vhosts/forum.dbpoweramp.com/httpdocs/global.php(389) : eval()'d code on line 3
    • 46228
    Re: Site Problem - frequent php error
    The DNS server at the datacenter is having issues, hopefully will sort its self soon.
