Id3 Tags?
  • KOF
    • Aug 2007
    • 53
    Id3 Tags?
    Hello guys once again nice program,
    Question I disable the " Write album art as folder", WINDOWS XP, after I've ripped the first cd. I go to the folder and I don't see nothing, When i copy the music from PC to mac the album art for example "small art, large art it shows like 5 of them and other stuff also. how can i disable this in order to have only the songs from the cd nothing else.
    Thank you,
    K'
    • 46228
    Re: Id3 Tags?
    On the ID Tag options page, uncheck album art.
    • KOF
      • Aug 2007
      • 53
      Re: Id3 Tags?
      I did w/o lock, and also unchecked the Album art and Album Artist from "Write ID tags" i have the same error,
      Also when i go to MY MUSIC FOLDER and click on the artist album folder / properties i can see the album art there,,
      Help me please..
      • KOF
        • Aug 2007
        • 53
        Re: Id3 Tags?
        Please help me.
        I did what you said and nothing happens do you know why is doing that?
        • KOF
          • Aug 2007
          • 53
          Re: Id3 Tags?
          help me.
            • 46228
            Re: Id3 Tags?
            So in CD Ripper:
            Options >>
            uncheck the 'write album art as folder.jpg'
            then click ID Tags >> Options
            and uncheck the Album Art option.
            Rerip the files.
            • KOF
              • Aug 2007
              • 53
              Re: Id3 Tags?
              So in CD Ripper:
              Options >>
              Rerip the files.
              Thank you, but it's the same I'm still seeing the album art inside the folder when i go to my music folder, I did what you toll me to, no success, please any more ideas
              • KOF
                • Aug 2007
                • 53
                Re: Id3 Tags?
                So in CD Ripper:
                Options >>
                Rerip the files.
                i had it off all the time in reference what you said above.
                  Re: Id3 Tags?
                  I think you are seeing album art from CDs ripped in Windows Media Player. Show hidden files in Windows Explorer and you should see the offending files.
                  • KOF
                    • Aug 2007
                    • 53
                    Re: Id3 Tags?
                    Ok,
                    But When I copy the folders to my externanl HD.(mac os x) I'm able to see those album art and the album artist so I have to delete myself to much trash, any ideas.. pleaee.
                    Why some of the folder shows a small album art and and other none,
                      Re: Id3 Tags?
                      As I said, if you see 5 hidden jpeg files in the folder, that CD was ripped with Windows Media Player. The only way to get rid of the files is to show hidden files in Windows and delete them.
                      • KOF
                        • Aug 2007
                        • 53
                        Re: Id3 Tags?
                        When you said the cd was ripped with WMP means that someone else did it right? because I use dbpoweramp cd ripper to rip my cds. When i go to "file view" and select show hide files" i don't see any of those albums.. it's something wrong with dBpoweramp..
                        Please help..
                          Re: Id3 Tags?
                          dMC writes one "folder.jpg" file when you tell it to write the album art to a folder.jpg. If you are seeing multiple JPEGs with names such as "album art large" and "album art small" and they are hidden, those files came from WMP, whether by ripping or applying meta-data to the files with WMP (not sure if applying the meta-data makes the album art). If you only rip CDs with dMC, then somebody else ripped the CDs.
                          Go into the folders that you said had the multiple files on the mac and you should see the hidden JPEGs now.
                          • KOF
                            • Aug 2007
                            • 53
                            Re: Id3 Tags?
                            Do you think that naming the file it could hurting something i have my naming settings like this:[album artist]\[album]\[track] [title]
                            also, the 12.2 version if i update to 12.3 do you think it might be help. I'm seeing this because before i didn't have any issues...
                              Re: Id3 Tags?
                              No, your naming scheme is fine. Upgrading to dMC r12.3 probably won't change anything. Could you post the exact filenames of the offending files you are seeing?
