Lame 3.93 is out ?
  • chami
    • Oct 2002
    • 13
    Lame 3.93 is out ?
    But not on
    Seems to work perfectly with dMC Audio CD Input
    (remplacement of
    C:\Program Files\Illustrate\dBpowerAMP\Compression\Lame\lame_ enc.dll )
    apparently 3.93.1 is out and it's stable.................
    but i notice that when i replace the dll, even though the file seems to convert properly, the resulting id3 tag says it's a xing(new) encode..............can this be fixed?
      Lame is supposed to write its version in at the beginning or the end, have a look in a hex editor.
