ID Tags
  • deepdiver
    • Mar 2006
    • 12
    ID Tags
    What is the easiest way to edit a large amount of mp3 files, so I can see it in the ipod
    Re: ID Tags
    What do you mean so you ipod can see them? Do you mean transfer your songs to the iPod?
    • deepdiver
      • Mar 2006
      • 12
      Re: ID Tags
      When I transfer my mp3 files from the pc to the ipod A lot of songs lost the id tags and only appear the track number or part the information is missing, example only the artist name or song name
        Re: ID Tags
        Do you MP3 files all have correct tags? Where did your mp3 files come from?
        What software are you using to transfer songs?
        • deepdiver
          • Mar 2006
          • 12
          Re: ID Tags
          The songs came from my cd´s, and from a Friend play list.
          I transfer the songs with the itunes,
          what will be the correct id tag ? ?
            Re: ID Tags
            By "correct tag" I mean do they have the correct artist, album, track name, etc?
            • deepdiver
              • Mar 2006
              • 12
              Re: ID Tags
              By correct Id tag I want to said the idtag that i need to use and do not lose the information when the song is transfer from the pc to the ipod
                Re: ID Tags
                The files that don't show up properly, are you sure they have correct tags? Right-click on the file in iTunes to see its information aka tags.
                Moved to the General section of this forum
                • hamah
                  • Jun 2007
                  Re: ID Tags
                  I'm not sure the question was answered here. What is the best way to bulk edit ID3 tags? I used to have an app bundled with Nero (can't recall which) that allowed this. I have a situation where I have a bunch of mp3s I converted from FLAC that have no tags (or tag elements). It is a pain to go and individually edit these tags by adding elements. Is there a way to create a template tag (Artist/Title/Album/Year etc) and then apply it to multiple songs? That way I'd only need to edit each for title and track number.
                    Re: ID Tags
                    dBpoweramp can, select all files >> right click >> Edit Tag.
                    Then change all the items you want in one go, then click single to type the track names using the > arrow to move to next file.
                    • hamah
                      • Jun 2007
                      Re: ID Tags
                      thanks! that works great.
