Changing BPM on iTunes songs
  • humesdae
    • Mar 2007
    I have a PC that has iTunes. I'm trying to find a program that I can download to the PC that I can use to make a playlist where all the BPM are the same.
    I need to take multiple songs from my existing library and change them to a specific BPM and then save them again to my library.
    Is there a program out there that does that now, or do I have to find a program to convert iTune songs to MP3 and then change the BPM at that point?
    Re: Changing BPM on iTunes songs
    If by "iTunes songs" you mean iTunes-puchased music, you will first have to remove the DRM on these files before utilities such as the one you need can be used.
    As for BMP-changing utilities, I have no idea, as I have never needed to use these before.
