Fix - For Missing Volume Control
This topic is closed.
  • Craze
    • Oct 2002
    • 308
    Here's the fix for a suddenly missing Volume Control I suspect occurred when Windows '98 froze during the process of updating new skin changes into my dAP player.
    The "X" and "Y" coordinates that position the volume control window from last opening got trashed in the registry.
    START>RUN...type REGEDIT...click OK.
    Expand tree for HKEY_CURRENT_ USER
    Click Software
    Use "EDIT" tab in tool bar...select FIND...type in VOLUME.
    Click FIND NEXT.
    Browse through registry until VOLUME CONTROL is found using F3 key to scroll with.
    Click on VOLUME CONTROL...X and Y should appear in top lines of the right pane window.
    Click on X.
    Right click X
    Select Modify
    Type in the number 5
    Click "DECIMAL" radio button
    Repeat for "Y".
    The values my X and Y had changed to from the freeze up were (3000)!
    These things happen.
    Crazy Curt
    Re: Fix - For Missing Volume Control
    Hey can anyone help? I deleted outlook express by accident now my volume control will not open and the icon is missing from the taskbar can anyone help with this matter I am going crazy with no sound on my computer.
      • 46228
      Sounds like your sound card has uninstalled rom Device Manager.
      • ANNA
        I cannot open my volume control. I have Windows ME. I tried what Craze said but it doesn't work. Is that because it was for windows '98? Can you please help me? I have been trying for days to figure this out. My e-mail is gorseam@aol.com. I would really appreciate the help.
          i have the same problem and still tryn to figure it out. try going to control panel/ sounds, speech, and audio device/ sound and audio devices properties. in there go to volume and there is a box that says "Place volume icon in the task bar", click on it and it should work. the problem i have is when i click on it, i get a error measage that says i have to install the "Volume Control" program and i dont know how to install it.
          • Razgo
            • 2532
            i only came across this when i did a fresh install of win98se. once i installed the audio drivers for my sound card it all came back.
            have you installed drivers for your sound card?
              I am going through the exact same thing!! PLEASE help...this is driving me crazy!!!
              Excuse my technological retardation, but how do I install these drivers you speak of, Razgo? At this point I will try ANYTHING! I have Windows XP by the way...
              • Razgo
                • 2532
                ok, anyone here with xp that can help?
                  Pleeeeeease?????
                  I've tried everything I can think of...which admitedly probably isn't much, but...
                    I followed the instructions below and did fine but after changing the values to "5" for x and y I have no radio button to click. What to do now?
                    Click Software
                    Click FIND NEXT.
                    Click on X.
                    Right click X
                    Select Modify
                    Repeat for "Y".
                    Crazy Curt
                      I tried the above. No luck at all.
                      Question: If I did a full system restore, would I lose everything I've saved to my drive?
                        thank you SO, SO much. i had the same problem with windows XP and that fix worked for me.
                          Copied Verbatim from http://www.jsiinc.com/SUBK/tip5200/rh5245.htm
                          --------------------------------SNIP---------------------------------
                          Top 20 Viewed Articles
                          1 How can I uninstall the Microsoft Java Virtual Machine (JVM) from Windows XP?
                          2 What You Need to Know About Windows Update Services
                          3 Enterprise Patch Management for Windows
                          4 Honeypots for Windows
                          5 Windows XP SP2 Will Bring Tablet PC Improvements
                          More Top Viewed Articles
                          John Savill
                          InstantDoc #39410
                          John Savill's FAQ for Windows
                          A. To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet. If, when you try to select this check box, you receive the error
                          Error
                          Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it, use Add/Remove Programs in Control Panel.
                          you need to copy the sndvol32.exe image from your commercial XP installation media (not a vendor-supplied "recovery" CD-ROM) to the system32 folder by performing the following steps:
                          1. Start a command session.
                          2. Navigate to the CD-ROM drive by typing
                          <cd drive>:
                          3. Navigate to the i386 folder by typing
                          cd i386
                          4. Expand the sndvol32.ex_ file by typing
                          expand -r sndvol32.ex_ %systemroot%\system32
                          Similar answer found here:
                            Post number 13 fixed it for me and I run WinXP Pro. Thanks for the help!
                              I found a link that has all the info on sound cards...
