Converting Real Audio voice files (.ra) to .mp3, the MP3 files I end up with are very considerably bigger than the originals.
I suspect the problem is that I'm selecting conversion parameters which, given the quality of the .ra files, are simply over the top -- ie I'm attempting to produce high quality MP3 from relatively low quality .ra.
Does anyone have any tips as to how you can determine the quality of the original .ra files, and how you might set about translating this into appropriate conversion paramters.
) which actually works quite well for me.
