Converting Bitrates
  • Romelskie
    • Oct 2002
    Converting Bitrates
    Hoi,
    Just wanna know how mp3 (e.g. bitrate 192) converting to a lower bitrate is working generally.
    Is that the same like decoding an mp3 to wav and then back to mp3 with a lower Bitrate?
    Thx for help,
    Regards Romelskie
    Yes, even if you converted it to 320kbps the new copy would be of less quality.
    • MasterOfPuppets
      • Nov 2002
      • 139
      whoa, how does that work?
      im used to the idea that converting to a higher bitrate than the original file will result in the same, but larger, file.
      Toute votre base sont appartiennent à nous!!!
      • daren
        • 153
        It's not always that simple. Cascading plays a role in audio
        compression, especially when converting between different
        formats (e.g. wma -> mp3, etc...). The first conversion throws
        information away and subsequent conversions (even to higher
        bitrates) throw different bits away.
        This is a big problem in broadcast situations where a journalist
        records on minidisc (for example), sends the audio via ISDN
        (mp2 64kbps), this gets recorded in mp2 256kbps, edited and
        bounced (another conversion) and transmitted via 192kbps
        MPEG transmission lines. Luckily journalists are moving over
        to compact flash recorders and contribution via FTP servers...
        Daren.
        • MasterOfPuppets
          • Nov 2002
          • 139
          kewl, thanx
