CDDB Protocol?
  • mule
    CDDB Protocol?
    I hope this is the right place...
    For my simple Music Player...
    I'de like to know how to know what CD I have.
    I know you need to connect to freedb.freedb.org/~cddb/cddb.cgi
    But what do I send? please help =\
  • mule
    Yey
    I found how to do it..
    But have another problem that maybe you can help me with.
    I need to send the "disc id", how can I know the disc id?
    And I need to send "Frame offset of the starting location of each track.", is this the starting point in seconds of each track?
      • 46186
      Have a look at freedb.org they give example code.
      • mule
        10x
        Thank you, I will skip on the DiscID, I found it's not that important and may work without.
        So for a start...I'll just need to know what the hell is "Frame Offset"?
        How do I retrive it from lets say...winamp for a file?
          • 46186
          It is all part and one of the same, Disc ID plus all the track offsets are needed that is what identifies a CD disc.
          • mule
            well...
            Well I may have a way to find the DiscID, but I have no clue what is the frame offset...?
