avatars
  • hiperpinguino
    • May 2002
    • 46
    avatars
    Was wondering if there is any way to use a self-made avatar in the forums... I know that it is possible using phpBB, and so I assume that it is possible with vB. If not, then it's obviously fine- it's just that I've got the same avatar going for every forum but this
    -Staff
    Reviews, Humor, and Random Insanity:
    www.n-chicken.net
  • Razgo
    • 2532
    email me the avatar at [email protected] and i will put it in the avatar list, then you can select it from the change avatar in your profile.
