SONY's ATRAC3 Sudden crash probem?
  • GALAXY
    • May 2006
    Hey all,
    I have a major problem relating to sonys sonicstage and its peeing me off bigstyle!!!
    Now, It starts up fine, but then crashes! I know it has something to do with the 'microsoft security update?' I have SP 2 installed, thus on Sonys site here, it says that should not happen, wats the crack lads?
    Even if Itry to download the countermeasure program it says I have the latest update and don't need to download it!
    need help deperatly!
    GXY
    Re: SONY's ATRAC3 Sudden crash probem?
    Moved to Spoon's Fourm as it is unrelated to dBpowerAMP products.
    • Exitao
      • May 2006
      What version are you using? I have that sp and am using SonicStage 3.4 with no problem.
      • raintheory
        • Mar 2006
        • 15
        Sonicstage CP (4.0) is now available...
        Try upgarding to that and see if it solves your problems.
        -raintheory
        • GALAXY
          • May 2006
          raintheory, thanks mate I'll try and see if that works!
          • GALAXY
            • May 2006
            THANKYOU raintheory, It works a dream now...
            thanks for all the help dudes and dudettes!
            Laters
            G-XY
