Problem with Taging not puting out right name
  • u2watcher
    • Mar 2006
    Hi I use foobar 2000 to rip my files and downloaded your program because I wanted to see tags with explorer the way you guys got it set up. My problem is foobar keeps on making my file names (not tags which are right) end up being 001 014EDDAD,01.flac as the filename. I did masstaging too and still gets this. Is there a setting that you can recommend that can make this work right. Foo worked fine before I downloaded this. I am using windows XP home. I also have all updates on everything thank you
    Re: Problem with Taging not puting out right name
    The two are 100% independant, dbpoweramp will not change anything with foobar, your support reuest should be on their forums.
      Moved to Off Topic located in Spoon's Forum.
