Winamp AAC commandline encoder
  • dimzon
    • Sep 2005
    • 14
    #31
    Re: Winamp AAC commandline encoder
    Originally posted by gameplaya15143
    but what about an option to use the 'high bitrate' encoder?
    --high :D
    and how about adding the resample option to set the encoder samplerate, instead of forcing it to use the same samplerate as the input?
    built-in resampler is not planned at all, use external resampler
    • dimzon
      • Sep 2005
      • 14
      #32
      my commad-line frontend (new version):
      • gameplaya15143
        • Sep 2005
        • 276
        #33
        Originally posted by dimzon
        --high :D
        :headbang: i saw --high yesterday.. i really need to learn how to read
        .... but doesn't enc_aacplus.dll have a resampler of its own built in?
        I'm just hoping to get access to it so I can input a 48khz file and encode it to 24khz (i would never actually do this...). I have an old frontend for enc_aacplus.dll that does provide access to the samplerate, so I know it exists..
        • dimzon
          • Sep 2005
          • 14
          #34
          enc_aacplus have its own built in resampler (at least 2:1) bcz it requed to AAC+ algorytm itself (AAC+ produce AAC-LC stream at half samplerate). But I can't invoke it (there are no way how to do it) for my own puposes
          Actually this is not resampler but actual source samplerate. When I wrote my first version of frontend I does not know how to obtain samplerate from WAV header (sic!) In current version samplerate obtained automatically...
          • gameplaya15143
            • Sep 2005
            • 276
            #35
            this your first one? http://www.crapshack.com/aacenc.zip
            cause what ive done here... http://www.geocities.com/gameplaya_1...dmc/index.html
            lets me input at 44.1khz and resample to 32khz
            p.s.: maybe you could put comments in your source code? so n00bs like me have a fighting chance at understanding/learning what is going on :lustig1:
            • dimzon
              • Sep 2005
              • 14
              #36
              Wow, i lost this source with my HDD many month ago!
              Ok, maybe You are right, take look @ it @ monday
              No comments :blush:
              If it was hard to write it must be hard to read :teufel8:
              • Dirkvl
                • Nov 2004
                • 30
                #37
                Dimzon has uploaded a new enc_aacplus.exe and it looks good !
                I've created a new aac plugin with options file adapted for using LC-AAC or HE-AAC.
                Winamp 5.2 is required (the exe I've made copies the needed enc-aacplus.dll to the plugin folder).
                Here it is : http://home.versateladsl.be/dirkvl14...I-20060317.exe
