dMCScripting for Dalet encoding
  • jmgarrido
    • Jan 2006
    How use dMCScripting for put Settings (Bitrate,Frecuency,ChannelMode) for Dalet encoding?
    Juan Manuel Garrido.
    • 46164
    Re: dMCScripting for Dalet encoding
    These values are in the registry (off the top of my head I don't know the specific names, but it will be obvious).
    check HKEY_CURRENT_USER\software\illustrate\dbpoweramp
    • jmgarrido
      • Jan 2006
      Thank you. I found these settings at registry.
      Can I change the padding bit in the header of the frames for this conversion? Some Dalet applications don't understand rightly the files converted with this codec.
      Thanks in advance for your help.
        • 46164
        For that question, it is best to ask the author reach him (Daren):
