VBScript for MP2 code
  • Boulli
    • Sep 2005
    I can access the Mp3Settings with the .vsb script like this:
    Set Mp3Settings = CreateObject("dMCScripting.Mp3Settings")
    Call Mp3Settings.Set(256, 48000, 0, 0)
    How can I do this for the MP2 codec I installed?????
    Thx, Roel
    Re: VBScript for MP2 code
    Moved to Developer
      You can call the codec (it will use the last used settings), to edit those settings you need to edit directly in the registry, somehwere in HKCU\software\illustrate\dbpoweramp
      • daren
        • 153
        The registry values you need to change are in HKCU\software\illustrate\dbpoweramp:
        DMCMP2BitRate
        DMCMP2Channels
        DMCMP2Freq
        I think they speak for themselves.
        Good luck!
        Daren.
