Enhanced AACPlus (AACPlus v2) Codec
  • dimzon
    • Sep 2005
    • 14
    #31
    Re: Playing the aacPlus files in Winamp 5
    Originally posted by Catrio
    Hi to everyone, Winamp is not capable for playing AAC files whit the `Plus“ enhancements because the files created for this codec be inside the MP4 container
    Use this decoder
    • Brian49
      • Sep 2004
      • 28
      #32
      Re: Enhanced AACPlus (AACPlus v2) Codec
      Originally posted by ckjnigel
      And Windows Media Player plays bsiegel AACplus files with the 3ivx codecs installed.
      Not on my system, I'm afraid. Any suggestions as to what to look for to solve this, please? The encoded files come out with an .mp4 extension. They play fine in Winamp (with the AudioCoding.com plugin) and in XMPlay (with the Mares plugin), but not in WMP or MPC. I have v.D4 4.5.1 of the 3ivxPro decoder installed, from the K-Lite codec pack. Many thanks.
        #33
        The player you use has to support AACPlus I would say, otherwise it just plays as a low-bitrate AAC file or not at all.
        • Brian49
          • Sep 2004
          • 28
          #34
          Sure, but bsiegel says in his introductory notes that the encoded files should play in WMP, and ckjnigel confirms that they do on his system with the 3ivx codecs installed. Although I must say that until I read these statements I wouldn't have expected WMP to play AAC+ files.
          • gameplaya15143
            • Sep 2005
            • 276
            #35
            i love free stuff :D but it seems to have 'pops' during playback
            i use winamp to play it, i can use directshow players thanks to coreaac and the haali media splitter
            i used to have 3ivx installed, but it liked to notify me when ever i opened something in a directshow player that the encoder trial was up.. way to annoying for me
            • Brian49
              • Sep 2004
              • 28
              #36
              An update: the encoded files will play in WMP after all, after installing a different set of codecs.
              • Tuner
                • Oct 2005
                It is possible to encode in bitrate 96kb/s?
                • gameplaya15143
                  • Sep 2005
                  • 276
                  #38
                  give it a try.. add
                  96 kbit/s stereo
                  96000 s
                  to options.txt, maybe it will work, i dont know
                  • sherl0k
                    • Nov 2005
                    The Enhanced AACPlus encoder will work only up to 64kbps, no higher. I'm unsure as to why, since I'm almost sure that higher bitrates were created, especially since it supports surround-sound.
                    Profressional version only, perhaps?
                    Chris
                    edit:: Winamp's free AACPlus encoder will encode to 128kbps. What's up with that?
                    • WBTCPIP
                      • Nov 2005
                      Hi BSiegel,
                      is it possible to add stdin stdout support to your encoder?
                      thank you!
                        #41
                        Doesn't AACPlus only go up to 128kbps? Higher than that, your probably better off using normal AAC
                        • gameplaya15143
                          • Sep 2005
                          • 276
                          #42
                          in my opinion, from 96kbps and up, use LC aac
                          • Brian49
                            • Sep 2004
                            • 28
                            #43
                            bsiegel - what's the future for your codec, please? Will you be finalising it and submitting it for inclusion in Codec Central? Many thanks.
                              • 46219
                              #44
                              If it has left beta, we can include a link from codec central.
                              • Phantazm
                                • Dec 2005
                                Anything new here? I would love to see this included in Codec Central, as it works perfectly for me. Needs a pretty installer though :D
