Noob Alert! Dumb question incoming!
    Installer seems to be a nice app... Might save me having to write my own
    I do seem to get a problem on the "Create Install..."
    Failure on creation of the temp files...
    Error box on each one saying it could not create the TMP file...
    Creates an empty install exe...
    Do I need the LZ compressor installed?
    Using version 9.0 from SourceForge...
    Any help would be superb!
    Re: Noob Alert! Dumb question incoming!
    Well, I installed ver 10 on another machine (WinME) and the DOS command to the LZ works file. Must be somthing in the command call in XP on my machine...
    I'll figure it out...
      You have a valid temp path setup for Windows?
