VB Automation
  • P Robidoux
    VB Automation
    I am looking for VB 6.0 (for Win 2000 / Win XP) sample code for basic player remote control of functions like:
    Set MyObject CreateObject (" ")
    Enque = "c:\file.mp3"
    Play
    Pause
    Stop
    and others ...
    What objects (*dll) do I have to refer to ...) ?
  • donny
    • Oct 2002
    • 761
    Re: VB Automation
    on dbpoweramp site in the developer section you have the commands for vb script, and I guess that they could be used in VB also... if not then take a look at the dbscripting.dll in the dbpoweramp directory... do note that it is writen in C++, but as far as I know you shouldn't have much problem, for instance I have imported with no trouble to Delphi....
      Re: VB Automation
      Would you advise me how to "... take a look at the dbscripting.dll (in the dbpoweramp directory)"
      - How to open a dll file ?
      I will not have problem translating from C++ to VB.
        • 46164
        Re: VB Automation
        No dlls, it is a com object - no linking required.
