Scripting: Entry for "Encoded with" ?
  • laserflor
    • Aug 2004
    Hello to all,
    I readed the article: http://www.dbpoweramp.com/developer-scripting.htm So I know, that I am able to "remote control" the dbPowerAMP Audio Player :smile2: i.e. with Delphi.
    I know, that the dbPowerAMP Musik Converter installs an explorer extension. After that, a tooltip is shown, when I mark a mp3-file.
    This tooltip shows among other things an entry called "Encoded with".
    Can I get this information within a dbPoweramp.Multiplayer object?
    Nice Greetings
    laserflor alias Rolf
    • 46164
    Re: Scripting: Entry for "Encoded with" ?
    Not possible, sorry.
      Hello Spoon,
      thank you for your quick answer.
      It's a pity, that I can't get this information.
      But.. Do you know, how the explorer extension gets this information from within the mp3-file, that I can fit this feature in my program?
      Nice greetings
        • 46164
        It is held within the decoding dll, the result is not passed out independantly, in theory it is possible with 'getpopupinfo.exe', what is your program?
        • laserflor
          • Aug 2004
          I am programming an application in Delphi, to catalogue my mp3-files. I know, there are many apps for that, but I wanted "mine". To play the mp3s, I use mpegdll.dll by Eugene Mayevski. I'm afraid, that the code doesn't work with mp3s from any encoders and causes general protection faults :( or invalid timecodes :( or doesn't play it :( . That's the reason, because I want to know, wich encoder did it. If it is not in the list, that works with mpegdll.dll, I would "convert" it with the dbPowerAMP converter.
          Nice greetings
          laserflor
            • 46164
            Here is how I call get popup:
            //------get a temp file-----
            STempFile TempFile("dBP");
            SFile File(TempFile.c(), GENERIC_WRITE | GENERIC_READ, CREATE_ALWAYS);
            if (File.IsOpen())
            char writeFileName[MAX_PATH];
            strcpy(writeFileName, Filename);
            File.WriteXBytesToFile(writeFileName, MAX_PATH);
            //------run popup get info-----
            char ToRun[MAX_PATH * 2];
            char PathMulti[MAX_PATH];
            GetApplicationPath(PathMulti);
            wsprintf(ToRun, "\"%sGetPopupInfo.exe\" <tempF>%s", PathMulti, TempFile.c());
            if (RunApplicationSpecial (ToRun, true))
            File.SetFilePos(0);
            Found = true;
            int Need = (int)File.GetThisFileSize();
            if (Need)
            char *pText = new char[Need];
            if (File.ReadXBytesFromFile(pText, Need))
            wSetString.SetStringUni8(pText);
            delete []pText;
            } else {
            Found = true;
            wSetString.SetString("Error GetPopupInfo.exe Not Found");
            Then pull out the encoded by string.
