-desiredb= setting in CLI
  • JayNYC
    • Feb 2008
    • 63
    Hi. When using CD Ripper to make regkey adjustments for later use with CLI, what does the parameter -desiredb= actually mean?
    is it
    (a) a post EBU analysis db adjustment up/down (the value set for -desireddb= is actually the amount to raise or lower after EBU analysis is complete)
    (b) the target loudness expressed in db instead of LUFS
    (c) something else
    thanks
    • 46224
    Re: -desiredb= setting in CLI
    For which DSP effect?
