codec api
  • Oniros
    • Nov 2018
    codec api
    Is there specific requirements to write codec working with dbpoweramp converter, any API ?
    • 46145
    Re: codec api
    An encoder? or both decoder and encoder?
    • Oniros
      • Nov 2018
      Re: codec api
      Hi, encoder only
        • 46145
        Re: codec api
        See:
        You an use the CLI encoder to call any other encoder.
        • Oniros
          • Nov 2018
          Re: codec api
          need to discuss more our situation, i've sent an email to you on thursday but get no answer, i would like to expose our need privatly, sent you pm
          • Oniros
            • Nov 2018
            Re: codec api
            Please answer to mp, i'ts quite urgent.
              • 46145
              Re: codec api
              We replied to your email.
              • Oniros
                • Nov 2018
                Re: codec api
                Mr Spoon, sorry to harass you but I haven't received any email, can you verify that the reply address matches the email I sent you on November 8, 2018 10:42
                  • 46145
                  Re: codec api
                  Resent
                  • Oniros
                    • Nov 2018
                    Re: codec api
                    Hi , did you get our email sent november 14 ?
                      • 46145
                      Re: codec api
                      Yes we will respond soon.
