questions about Resample DSP
  • JayNYC
    • Feb 2008
    • 63
    If used from the command line...
    1. is Resample the latest-greatest DBpoweramp sample rate conversion engine, the one which features so well on the famous Infinite Waves SRC comparison site?
    2. Can I set both the Min and Max for Resample to 44100, so that if any file other than a 44.1 file is input, it will get converted to 44.1, and if 44.1 is input, Resample processing is skipped?
    3. Can I set Resample to output 24 bit instead of 16 bit if (and only if) it processed a file other than 44.1? In other words, if a 16/44.1 file is input, the output file be 16/44.1 ; but if a 16/48 file is input, the output file will be 24/44.1 ?
    thanks
    • 46147
    Re: questions about Resample DSP
    1. Yes
    2. Yes
    3. Not possible.
    • JayNYC
      • Feb 2008
      • 63
      Thank you for the fast reply. For the scenario *2 above, if I use this command line syntax
      Code:
      "C:\Program Files (x86)\Illustrate\dBpoweramp\coreconverter.exe" -infile=%%A -outfile="M:\DJ\jDJproj\Trax\2B-Warped\%%~nA.aiff" -dspeffect1="Resample=-fmin={qt}44100{qt} -fmax={qt}44100{qt}" -convert_to="AIFF"
      it outputs the following
      Code:
      dBpoweramp Music Converter           (C) 2009 Illustrate Ltd
      Encoding: AIFF
      Audio Source: M:\MUSIC-BANK\misc\oct16\Uncharted - ManuMan x icekream.mp3
      Audio Destination: M:\DJ\jDJproj\Trax\2B-Warped\Uncharted - ManuMan x icekream.aiff
      DSP Effects: Resample
       0%-----------25%-----------50%-----------75%-----------100%
       Error DSP Resample Frequency not supported:
        Destination Audio Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 48000  Bytes Per Second: 192000  Block Al
      ign: 4  CB Size: 0
      Writing ID Tags: Done
      Conversion Failed.
      The input file is 16/48. Curious why this is failing.
        • 46147
        You would have to enable debug log to see what it says, run dBpoweramp configuration.
        • JayNYC
          • Feb 2008
          • 63
          Code:
          Splitting Command Line:Done
          Decodes  [clDecoder::Get]
          ->->  [cldBCodecHandler::LoadEncoder]
            Loading Encoder 'C:\Program Files (x86)\Illustrate\dBpoweramp\encoder\AIFF.DLL'
          <-<-  [cldBCodecHandler::LoadEncoder]
          ->->  [dBCoreConverter::StripCoreConverterCmds]
          <-<-  [dBCoreConverter::StripCoreConverterCmds]
          SendRawUnCompressed  [clEncoder::Get]
          IsLive  [clDSP::Get]
          SendOverReplayGainTags  [clDSP::Get]
          Communicate  [clDecoder::Get]
          Communicate  [clEncoder::Get]
          NeedHQAudio  [clEncoder::Get]
          ->->  [clDecoder::Open]
            Opening file 'M:\MUSIC-BANK\misc\oct16\Uncharted - ManuMan x icekream.mp3' for read access: Opened
            ->->  [clDecoder::ReadIDTags]
              Reading Tag: APE contained 0 tags:
              Reading Tag: ID3v2 contained 20 tags:
          			Artist: ManuMan x icekream
          			Comment iTunNORM:  00000ADA 00000BBE 0000B4EB 0000B59D 0001F728 0001F728 0000929B 0000914A 00037AA0 0001E078
          			Comment iTunSMPB:  00000000 00000210 00000870 0000000000B0F400 00000000 009360C0 00000000 00000000 00000000 00000000 00000000 00000000
          			Dynamic Range (DR): 6
          			Dynamic Range (R128): 7.9068398475646972
          			Encoder Settings: Logic 10.0.7
          			Genre: Pirate Trap
          			Peak Level (R128): +0.7 dBTP; +0.6 Left; +0.7 Right
          			Peak Level (Sample): +0.0 dB; +0.0 Left; +0.0 Right
          			replaygain_track_gain: -6.68 dB
          			replaygain_track_peak: 1.000000
          			Tempo: 72
          			Title: Uncharted
          			Tool Name: Media Center
          			Tool Version: 20.0.131
          			Volume Level (R128): -11.6754798889160156
          			Volume Level (ReplayGain): -6.6754798889160156
          			_albumart_1_Undefined: DATA Length: 4360069   ....DdExif..MM.*....
          			_albumart_2_Undefined: DATA Length: 3865309   ....>GExif..MM.*....
          			_albumart_3_Undefined: DATA Length: 157765   ......JFIF.....d.d..
              Reading Tag: ID3v1 contained 2 tags:
          			Title: Uncharted
            <-<-  [clDecoder::ReadIDTags]
            ->->  [clsmpeg123::Init]
              mpeg data stream begins at byte position: 8384512
            <-<-  [clsmpeg123::Init]
            ->->  [clDecoder::FillAudioProps]
          	Audio Quality: Very High  (Lossy)
          	Encoder: FHG (Guess)
          	Encoder Settings: Constant Bit Rate 320 kbps
          	Channel Mapping: Left, Right
          	Channel Coupling: Joint-Stereo
          	Sample Count: 11,599,488
          	MPEG Version: MPEG 1 Layer III
          	MPEG Technical: Header: (none)   Bits: (none)
          	ID Tag: ID3v2.3 & ID3v1.0
          	Contains: Album Art, ReplayGain, ID Tag [ID3v2.3 & ID3v1.0]
          	Gapless: No
            <-<-  [clDecoder::FillAudioProps]
            ->->  [clDecoder::FillAudioInfo]
              Uncompressed WFX (sent to db): Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 48000  Bytes Per Second: 192000  Block Align: 4  CB Size: 0
              Audio Length: 241656 mili-seconds  9666240 bytes  320 kbps
            <-<-  [clDecoder::FillAudioInfo]
            Creating Decode Buffer: Created
          <-<-  [clDecoder::Open]
          SendOverReplayGainTags  [clEncoder::Get]
          ->->  [clDSP::BeginConversion]
          *** Error: Error DSP Resample Frequency not supported:
              Source Audio Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 48000  Bytes Per Second: 192000  Block Align: 4  CB Size: 0
          *** Error:   Destination Audio Format Tag: 1  Channels: 2  Bits per Sample: 16  Samples Per Second: 48000  Bytes Per Second: 192000  Block Align: 4  CB Size: 0
          <-<-  [clDSP::BeginConversion]
          ->->  [clEncoder::BeginConversion]
            Professional sample rate conversion.
            Converting to 'M:\DJ\jDJproj\Trax\2B-Warped\Uncharted - ManuMan x icekream.aiff.tmp.aiff' encoder settings ''
            ->->  [clAIFFHandler::InitializeNewAIFF]
              clAIFFHandler::CalcAllChunks: Ok
              ->->  [clAIFFHandler::AddChunk]
                ->-> Adding Chunk 'COMM' Length: 18  [clAIFFHandler::AddChunk]
                <-<-  [clAIFFHandler::AddChunk]
                  ->-> Adding Chunk 'SSND' Length: 0  [clAIFFHandler::AddChunk]
                  ->->  [clAIFFHandler::WriteChunkHeaders]
                    Writing Chunk Header 'COMM'  Length: 18  ChunkPosition: 12  ChunkDataPos: 20
                    Writing Chunk Header 'SSND'  Length: 0  ChunkPosition: 38  ChunkDataPos: 46
                  <-<- Exit as only write to SSND chunk  [clAIFFHandler::WriteChunkHeaders]
                  Writing Chunk Data 'COMM'  Length: 18  ChunkPosition: 12  ChunkDataPos: 20
                <-<-  [clAIFFHandler::InitializeNewAIFF]
                Writing STSoundData
              <-<-  [clEncoder::BeginConversion]
          Encoding To: AIFF
          Encoder Cmd Line:
          DSP Effects:
              Resample: -fmin="44100" -fmax="44100"
          ->->  [dBCoreConverter::CloseDecoder]
          ->->  [clDecoder::Close]
          <-<-  [clDecoder::Close]
          ->->  [clDSP::EndConversion]
          <-<-  [clDSP::EndConversion]
              ->->  [clEncoder::EndConversion]
                  Writing Chunk Header 'SSND'  Length: 65540  ChunkPosition: 38  ChunkDataPos: 46
                <-<-  [clAIFFHandler::WriteChunkHeaders]
              <-<-  [clEncoder::EndConversion]
            File Size Check (before overwrite final): 65586 bytes   Filename: M:\DJ\jDJproj\Trax\2B-Warped\Uncharted - ManuMan x icekream.aiff.tmp.aiff
          ->->  [clDSP::AfterConversion]
          <-<-  [clDSP::AfterConversion]
            • 46147
            I have tried your command line and it works fine with R16, it must have been an issue resolved over the many years (your version is 7 years old).
            • NealXu
              • Jan 2018
              Hi...How are you calculating the expected number of samples per block? Filters and interpolators used in resampling will ring producing more samples. These extra tailing samples need to overlap adjacent blocks. Maybe you already know this, but without seeing the code, or even what kind of upsampling, downsampling and interpolation procedures you're using, it's hard to know where the problem is.
              • XYZ000
                • Feb 2021
                • 29
                Is it possible, now after many updates of the software, to somehow set this within the GUI options?
                I need to have in my shell menu entries that will convert audio files to WAVs and other audio formats that will have always 44 kHz - I do not want them to inherit kHz resolution of the source material
                  • 46147
                  Use the DSP effect resample and set it to 44.1KHz
                  • XYZ000
                    • Feb 2021
                    • 29
                    But how / where?
                    I cannot find it
                      • 46147
                      Are you using R17 ? it is in the list of DSP effects, either in Music Converter or on the DSP tab in CD Ripper.
                      • XYZ000
                        • Feb 2021
                        • 29
                        And so it is available under
                        DSP Effects > Add > Add DSP Effect > Resample
                        and not merely as a one-click-box for every format
                        Now I see it, thank you
