R16.1 Feature request: coreconverter.exe return code for error
  • chrisjj
    • Nov 2008
    • 300
    Please make coreconverter.exe return code be non=zero in event of error.
    Currently the lack of a return code indicating error makes CoreConverter.exe not properly usable on many environment. It is standard for command-line programs to indicate errors in the return code. Since it doesn't to that, CoreConverter.exe doesn't fit properly in everything from MAKE to PowerShell.
    Workaround: code a wrapper that
    1 creates a unique temporary filename
    2 passes it by -errorfile=
    3 returns non-zero if thw temp file is non-empty
    4 deletes the temp file
    5 risks fail if anything goes wrong with the tempfile e.g. out of disc space.
    • 44039
    Re: R16.1 Feature request: coreconverter.exe return code for error
    I have just tested R16 and it does return the correct error code, 0 if no error, 1 for an error. This code was used to test:
    DWORD exit_code = 0;
    GetExitCodeProcess(proc.hProcess, &exit_code);
