Dynamic CLI for MP3HD (MP3 Lossless, not a recommended format!)
  • Lynx_TWO
    • Aug 2009
    • 85
    I created this due to someone on the forum asking about the format. You can download the encoder and decoder for MP3HD here: [HTML]http://mp3hd-toolkit.soft32.com/[/HTML]
    Known bugs:
    When telling dBpoweramp to write ID3 tags to the file, only the lossy portion of the MP3 is saved. Even with the
    Code:
    -nodbtag
    switch and writing tags using the
    Code:
    -id3in
    switch it still stripts out the lossless portion stored in the tag.
    I wouldn't recommend anyone using this encoder as the correction data is in the ID3 tag, because mp3 doesn't allow frame sizes large enough. Therefore, your lossless collection could too easily be lost with a basic mass-tagging operation.
    The lossless part of the codec is stored in ID3v2 tags.
    The size of ID3v2 tags is limited to 256MB by specifications; as a result, the lossless part of an mp3hd file may not be over 256MB.
    You have been warned!
    On the flipside, you apparently get a true Fraunhofer MP3 encoder for normal MP3 if you tag files, so there’s that…
    If you want to only encode to lossless, just use the cli encoder, uncheck Write Tags, place .mp3 only in the encoder.txt file, and the switches
    Code:
    -if [infile] -of "[outfile]"
    Dynamic CLI below:
    Code:
    [codec]
    .mp3
    mp3hdEncoder.exe
    [msgifnoencoder]
    Before using this encoder MP3HDEncoder.exe must first be downloaded (Google "Thomson mp3HD software Toolkit", or go here: http://mp3hd-toolkit.soft32.com/ ).
    [label]
    4
    0
    Mode
    [radio&slider]
    4
    36
    292
    1
    26
    0
    VBR + Correction
    13
    VBR5 ~114 kbps (0.3%>FLAC)
    -mode 5
    VBR4 ~137 kbps (2.0%>FLAC)
    -mode 4
    VBR3 ~147 kbps (2.2%>FLAC)
    -mode 3
    VBR2 ~188 kbps (2.0%>FLAC)
    -mode 2
    VBR1 ~216 kbps (5.1%>FLAC)
    -mode 1
    [/sliderend]
    99
    0
    CBR (common CBR)
    8
    96 kbps (min)
    -br 96000
    112 kbps
    -br 112000
    128 kbps
    -br 128000
    144 kbps
    -br 144000
    160 kbps
    -br 160000
    176 kbps
    -br 176000
    192 kbps
    -br 192000
    224 kbps
    -br 224000
    256 kbps
    -br 256000
    320 kbps
    -br 320000
    [/sliderend]
    180
    0
    CBR (Fine) + Correction
    8
    96 kbps (min)
    -br 96000
    97 kbps
    -br 97000
    98 kbps
    -br 98000
    99 kbps
    -br 99000
    100 kbps
    -br 100000
    101 kbps
    -br 101000
    102 kbps
    -br 102000
    103 kbps
    -br 103000
    104 kbps
    -br 104000
    105 kbps
    -br 105000
    106 kbps
    -br 106000
    107 kbps
    -br 107000
    108 kbps
    -br 108000
    109 kbps
    -br 109000
    110 kbps
    -br 110000
    111 kbps
    -br 111000
    112 kbps
    -br 112000
    113 kbps
    -br 113000
    114 kbps
    -br 114000
    115 kbps
    -br 115000
    116 kbps
    -br 116000
    117 kbps
    -br 117000
    118 kbps
    -br 118000
    119 kbps
    -br 119000
    120 kbps
    -br 120000
    121 kbps
    -br 121000
    122 kbps
    -br 122000
    123 kbps
    -br 123000
    124 kbps
    -br 124000
    125 kbps
    -br 125000
    126 kbps
    -br 126000
    127 kbps
    -br 127000
    128 kbps
    -br 128000
    129 kbps
    -br 129000
    130 kbps
    -br 130000
    131 kbps
    -br 131000
    132 kbps
    -br 132000
    133 kbps
    -br 133000
    134 kbps
    -br 134000
    135 kbps
    -br 135000
    136 kbps
    -br 136000
    137 kbps
    -br 137000
    138 kbps
    -br 138000
    139 kbps
    -br 139000
    140 kbps
    -br 140000
    141 kbps
    -br 141000
    142 kbps
    -br 142000
    143 kbps
    -br 143000
    144 kbps
    -br 144000
    145 kbps
    -br 145000
    146 kbps
    -br 146000
    147 kbps
    -br 147000
    148 kbps
    -br 148000
    149 kbps
    -br 149000
    150 kbps
    -br 150000
    151 kbps
    -br 151000
    152 kbps
    -br 152000
    153 kbps
    -br 153000
    154 kbps
    -br 154000
    155 kbps
    -br 155000
    156 kbps
    -br 156000
    157 kbps
    -br 157000
    158 kbps
    -br 158000
    159 kbps
    -br 159000
    160 kbps
    -br 160000
    161 kbps
    -br 161000
    162 kbps
    -br 162000
    163 kbps
    -br 163000
    164 kbps
    -br 164000
    165 kbps
    -br 165000
    166 kbps
    -br 166000
    167 kbps
    -br 167000
    168 kbps
    -br 168000
    169 kbps
    -br 169000
    170 kbps
    -br 170000
    171 kbps
    -br 171000
    172 kbps
    -br 172000
    173 kbps
    -br 173000
    174 kbps
    -br 174000
    175 kbps
    -br 175000
    176 kbps
    -br 176000
    177 kbps
    -br 177000
    178 kbps
    -br 178000
    179 kbps
    -br 179000
    180 kbps
    -br 180000
    181 kbps
    -br 181000
    182 kbps
    -br 182000
    183 kbps
    -br 183000
    184 kbps
    -br 184000
    185 kbps
    -br 185000
    186 kbps
    -br 186000
    187 kbps
    -br 187000
    188 kbps
    -br 188000
    189 kbps
    -br 189000
    190 kbps
    -br 190000
    191 kbps
    -br 191000
    192 kbps
    -br 192000
    193 kbps
    -br 193000
    194 kbps
    -br 194000
    195 kbps
    -br 195000
    196 kbps
    -br 196000
    197 kbps
    -br 197000
    198 kbps
    -br 198000
    199 kbps
    -br 199000
    200 kbps
    -br 200000
    201 kbps
    -br 201000
    202 kbps
    -br 202000
    203 kbps
    -br 203000
    204 kbps
    -br 204000
    205 kbps
    -br 205000
    206 kbps
    -br 206000
    207 kbps
    -br 207000
    208 kbps
    -br 208000
    209 kbps
    -br 209000
    210 kbps
    -br 210000
    211 kbps
    -br 211000
    212 kbps
    -br 212000
    213 kbps
    -br 213000
    214 kbps
    -br 214000
    215 kbps
    -br 215000
    216 kbps
    -br 216000
    217 kbps
    -br 217000
    218 kbps
    -br 218000
    219 kbps
    -br 219000
    220 kbps
    -br 220000
    221 kbps
    -br 221000
    222 kbps
    -br 222000
    223 kbps
    -br 223000
    224 kbps
    -br 224000
    225 kbps
    -br 225000
    226 kbps
    -br 226000
    227 kbps
    -br 227000
    228 kbps
    -br 228000
    229 kbps
    -br 229000
    230 kbps
    -br 230000
    231 kbps
    -br 231000
    232 kbps
    -br 232000
    233 kbps
    -br 233000
    234 kbps
    -br 234000
    235 kbps
    -br 235000
    236 kbps
    -br 236000
    237 kbps
    -br 237000
    238 kbps
    -br 238000
    239 kbps
    -br 239000
    240 kbps
    -br 240000
    241 kbps
    -br 241000
    242 kbps
    -br 242000
    243 kbps
    -br 243000
    244 kbps
    -br 244000
    245 kbps
    -br 245000
    246 kbps
    -br 246000
    247 kbps
    -br 247000
    248 kbps
    -br 248000
    249 kbps
    -br 249000
    250 kbps
    -br 250000
    251 kbps
    -br 251000
    252 kbps
    -br 252000
    253 kbps
    -br 253000
    254 kbps
    -br 254000
    255 kbps
    -br 255000
    256 kbps
    -br 256000
    257 kbps
    -br 257000
    258 kbps
    -br 258000
    259 kbps
    -br 259000
    260 kbps
    -br 260000
    261 kbps
    -br 261000
    262 kbps
    -br 262000
    263 kbps
    -br 263000
    264 kbps
    -br 264000
    265 kbps
    -br 265000
    266 kbps
    -br 266000
    267 kbps
    -br 267000
    268 kbps
    -br 268000
    269 kbps
    -br 269000
    270 kbps
    -br 270000
    271 kbps
    -br 271000
    272 kbps
    -br 272000
    273 kbps
    -br 273000
    274 kbps
    -br 274000
    275 kbps
    -br 275000
    276 kbps
    -br 276000
    277 kbps
    -br 277000
    278 kbps
    -br 278000
    279 kbps
    -br 279000
    280 kbps
    -br 280000
    281 kbps
    -br 281000
    282 kbps
    -br 282000
    283 kbps
    -br 283000
    284 kbps
    -br 284000
    285 kbps
    -br 285000
    286 kbps
    -br 286000
    287 kbps
    -br 287000
    288 kbps
    -br 288000
    289 kbps
    -br 289000
    290 kbps
    -br 290000
    291 kbps
    -br 291000
    292 kbps
    -br 292000
    293 kbps
    -br 293000
    294 kbps
    -br 294000
    295 kbps
    -br 295000
    296 kbps
    -br 296000
    297 kbps
    -br 297000
    298 kbps
    -br 298000
    299 kbps
    -br 299000
    300 kbps
    -br 300000
    301 kbps
    -br 301000
    302 kbps
    -br 302000
    303 kbps
    -br 303000
    304 kbps
    -br 304000
    305 kbps
    -br 305000
    306 kbps
    -br 306000
    307 kbps
    -br 307000
    308 kbps
    -br 308000
    309 kbps
    -br 309000
    310 kbps
    -br 310000
    311 kbps
    -br 311000
    312 kbps
    -br 312000
    313 kbps
    -br 313000
    314 kbps
    -br 314000
    315 kbps
    -br 315000
    316 kbps
    -br 316000
    317 kbps
    -br 317000
    318 kbps
    -br 318000
    319 kbps
    -br 319000
    320 kbps (max)
    -br 320000
    [/sliderend]
    85 - out of gas
    [checkbox]
    30
    14
    0
     No ID3 v1 Tags
     -noid3v1
    [label]
    10
    55
    <Lossy Quality
    808080
    [label]
    235
    55
    Lossy Quality>
    808080
    [clistring]
     -nodbtag -if [infile] -of "[outfile]" -id3in -Title "[title]" -Artist "[artist]" -Album "[album]" -Track [track]
    [noallowfloat]
    [maxchannels]
    2
    [estimatesize]
    114000
    137000
    147000
    188000
    216000
    MP3HD help file with switches:
    [PHP]************************************************** ***************************
    * mp3HD Codec V1.5.0 *
    * (Evaluation Version) *
    * (c) 2007 - 2010 Technicolor S.A. *
    * (c) 1996 - 2010 Fraunhofer IIS *
    * All rights reserved. *
    * This software and/or program is protected by copyright law and *
    * international treaties. Any reproduction or distribution of *
    * this software and/or program, or any portion of it, may result *
    * in severe civil and criminal penalties, and will be prosecuted *
    * to the maximum extent possible under law. *
    Origin
    Website: http://www.all4mp3.com
    Contact: [email protected]
    Software package
    This package contains the following software:
    - mp3HD Command-Line Encoder: mp3hdEncoder.exe
    - mp3HD Command-Line Decoder: mp3hdDecoder.exe
    - Winamp Decoder Plug-Ins:
    Winamp 5.5 and above: in_mp3hd.dll
    System requirements
    Minimum requirements for the use of the software are:
    - Windows 2000/Windows XP
    - At least Pentium III 1 Ghz or higher
    - At least 128 MB memory
    - At least 30MB of available hard-disk space
    - Winamp V5.5 or higher plus stereo soundcard for playback
    The mp3HD Format (Some Terminology)
    mp3HD is a new scalable format for high-quality lossless compression
    of audio signals. It guarantees bit-exact reproduction of the
    original PCM samples at state-of-the-art compression ratios. As for
    all lossless compression formats, the compression ratio and resulting
    data rate depends on the compressed content. As a rule of thumb, the
    mp3HD codec can compress WAV files to about 30% to 60% of their
    original size for typical audio content. Typically, smaller data
    rates are needed to encode classical music or audio books, while Rock
    and Pop music requires larger data rates.
    mp3HD has been designed with the explicit target to be as compatible
    as possible to the ubiquitous MP3 format. As a consequence, the mp3HD
    format uses advanced compression algorithms and a special bit stream
    format in order to be compatible to most of the available MP3 players.
    Therefore mp3HD is both a lossless format for the reproduction of the
    original PCM samples and a standard MP3 file that play's on your MP3
    player.
    The mp3HD Format supports tagging the files with meta data according
    to ID3 Version 1.0, 1.1, 2.3 and 2.4. That is, you can use many
    existing tools to add ID3 tags to your mp3HD content, and to manage
    and organize your audio collection.
    This program encodes WAV audio files to mp3HD files. The WAV audio
    files have to contain plain PCM samples in mono or stereo with a
    resolution of 16 bit per sample. The sample rate is restricted to one
    out of 32 kHz, 44.1 kHz, or 48 kHz.
    It is in the nature of lossless audio compression that the resulting
    bit rate is inherently defined by the audio content. Consequently,
    the bit rate of the mp3HD file cannot be specified. However, the
    target bit rate for the backwards-compatible MP3 bit stream already
    has to be specified at the time of encoding the mp3HD file. You can
    select both variable bit rate (VBR) mode at several qualities or
    constant bit rate (CBR) mode for the resulting MP3 via the
    command-line argument "-mode".
    For CBR mode you can further define the data rate for the resulting
    MP3 file. The range of possible bit rates is constrained as follows:
    Stereo signals:
    - sample rate of 32 kHz: 80000 - 320000 bit/s
    - sample rate of 44.1 kHz: 96000 - 320000 bit/s
    - sample rate of 48 kHz: 112000 - 320000 bit/s
    Mono signals:
    - sample rate of 32 kHz: 40000 - 320000 bit/s
    - sample rate of 44.1 kHz: 56000 - 320000 bit/s
    - sample rate of 48 kHz: 56000 - 320000 bit/s
    To add existing ID3 meta data to the mp3HD file use the command-line
    arguments "-id3in" to pass an existing ID3 (Ver. 2.3 or 2.4) meta data
    file to the mp3HD encoder. For example, the file can be an existing mp3
    file that includes the desired ID3 tag information.
    Alternatively, you can use the following command-line arguments to set
    the ID3 meta data directly:
    -Title "[title string]"
    -Artist "[artist string]"
    -Album "[album string]"
    -Track "[track number]"
    -Length "[length in ms]"
    -Year "[year string]"
    -Genre "[content type]"
    -Encoder "[encoded by ..]"
    -Encoder_Settings "[encoder name and settings]"
    -pic "[jpegFile]"
    The "-id3in" command-line argument can't be used in combination
    with the other ID3 command-line arguments.
    To call the mp3HD command-line encoder simply open a command prompt
    and enter "mp3hdEncoder". If called without arguments, the encoder
    outputs a list of possible command-line arguments and encoding
    options.
    This program decodes mp3 and mp3HD files to WAV audio files. The output
    files contain bit-exactly the same PCM samples as the originally encoded
    WAV files.
    Note that the mp3HD decoder cannot reconstruct any side information,
    i.e. additional chunks besides the actual audio data, that may have
    been contained in the original WAV file. Therefore, you may observe
    differences if you compare the decoded WAV file with the original WAV
    file on the file level.
    To call the command-line decoder simply open a command prompt and
    enter "mp3hdDecoder". If called without arguments, the decoder
    outputs a list of possible command-line arguments and decoding
    options.
    mp3HD Winamp Decoder
    If you have a Winamp player installed, the mp3HD format can be added
    to the audio formats supported by the player. By default, the mp3HD
    Winamp Decoder plugin decodes mp3HD files in mp3HD quality, i.e. the
    high-quality original PCM samples are played.
    You may configure the plugin to play mp3 quality instead of mp3HD quality
    by default. In addition, you can activate in the settings dialog to
    display a window in which you can switch between mp3 quality and mp3HD
    quality in real time while decoding an mp3HD file.
    We recommend to use Winamp version 5.5 or above. The new version of
    the Winamp player can be downloaded at http://www.winamp.com.
    To install the Winamp decoder plug-in copy the "in_mp3hd.dll" file to
    your local Winamp plug-in folder. Typically, the directory of the Winamp
    plug-in folder is "C:\Program Files\Winamp\plugin".
    FAQ
    ** What are PCM samples?
    The acronym PCM stands for pulse code modulation. In most digital
    workflows, PCM samples describe the raw digital audio signals
    either right after conversion from the analog domain or before
    conversion to the analog domain.
    PCM samples are not compressed like e.g. MP3 files. Therefore,
    they offer in principle the best possible sound quality for a given
    sample rate and resolution. As an example, a CD stores audio as
    PCM samples with a rate of 44100 samples per second (and channel)
    and a resolution of 16 bit per sample. This gives a bit rate of
    1411.2 kbit/s.
    ** Can I use the mp3HD Codec to rip my audio CDs?
    To rip mp3HD files from your audio CDs you need an audio CD
    grabber tool with external Encoder support. For example you can use
    the Exact Audio Copy CD grabber. The current version of Exact Audio
    Copy can be downloaded at
    http://www.exactaudiocopy.de/en/index.php/resources/download/.
    You can include the mp3HD encoder into the Exact Audio Copy grabber
    by performing the following steps:
    - Open the "Compression options" from the "EAC" menu
    - Go to the "External Compression" tab
    - Enable the "Use external program for compression" option
    - Set "Parameter passing scheme" to "User Defined Encoder"
    - Write ".mp3" into the "Use file extension" field
    - Type the link to your mp3hdEncoder.exe file into the
    "Program, including Path, used for compression" field
    - Insert the following text into the Additional command-line option field:
    -if %s -of %d -br %r000 -Artist "%a" -Album "%g" -Title "%t" -Year "%y"
    -Track "%n" -Genre "%m"
    - Select the desired bit rate in the "Bit rate" field.
    - Uncheck the "Add ID3 tag" option
    Version History & Release Notes
    V1.4.0 First public release of the mp3HD Codec
    V1.4.1 First public release for Mac OS
    Bug Fix: Winamp pause button didn't work for standard mp3 files
    V1.4.2 Command-line argument changes in the mp3hdEncoder
    Minor bug fixes
    V1.5.0 Faster En- and Decoding
    Decoding of plain mp3 files
    Original File Length support for plain mp3 files
    Some minor bug fixes
    Encoding of very short input signals
    Automatic resynchronization to the mp3HD stream on errors
    Redesign of the mp3HD Winamp quality switch
    Changed the default ID3 tag version of the mp3HD Encoder to 2.4
    Automatically adds ID3v1 tags to the end of the file
    * mp3HD Commandline Encoder v1.5.0 *
    * using mp3HD library v1.1.7 *
    * Revision 487 *
    * Build Feb 2 2010 *
    Usage: mp3hdEncoder.exe [-if infile] [-of outfile] [-br Birate] [options]
    -if infile:
    A 1 channel or 2 channel wave input file.
    -of outfile:
    The destination mp3HD bitstream file.
    [options]:
    -br Bitrate
    The MP3 bitrate in bits/sec <default: 128 Kbit/s>
    -mode <0-5>
    Encoder mode (0 = CBR, 1 = VBR highest quality, 5 = VBR lowest
    bit rate) <default: CBR>
    VBR mode 5 is disabled for infiles with 48 kHz samplerate.
    -id3in id3File
    The id3File can contain an ID3V1.x and an ID3V2.3 or an ID3V2.4 tag.
    The ID3 tags are copied into the mp3HD file.
    The ID3V2.X tag has to be at the beginning of the file.
    The ID3V1.x tag has to be at the end of the file.
    Add ID3 tags directly:
    (Ignored in combination with the "-id3in" option)
    -pic jpegFile
    The jpegFile must contain an jpeg picture.
    The picture is copied into the mp3HD file.
    -noid3v1
    The noid3v1 flag disables the writing of ID3v1 tags.
    -com "[Text]"
    Adds a comment text into the mp3HD info frame.
    -quiet
    Standard output of only one line
    Example: mp3hdEncoder.exe -br 128000 -if test.wav -of test.mp3[/PHP]
