Possible to adjust track gain based on ebur128 LKFS measurement?
  • JayNYC
    • Feb 2008
    • 63
    Hi. So I have a .bat file on Windows 7 that runs a bunch of different audio manipulations on any track that I send it.
    I would like to add the following step, if possible:
    Adjust the gain of a track such that that the peak of the track is -10 LKFS according to an ebuR128 evaluation.
    In other words, I want to permanently adjust a track such that the loudest part is no louder and no softer than -10 LKFS.
    Can I accomplish this with dbpoweramp reference version? If so, how?
    --jay
    • 46164
    Re: Possible to adjust track gain based on ebur128 LKFS measurement?
    Yes, on the EBU settings page you change the reference loudness volume, for Replaygain >> Advanced >>LUFS Target Volume. Then run a 2nd batch with ReplayGain (Apply)
    • JayNYC
      • Feb 2008
      • 63
      Hi Spoon, thank you for the quick reply.
      1. where do I access the "EBU settings page" to change reference loudness volume?
      2. will this technique adjust the gain of the track for Integrated Loudness or for Peak Loudness? I am trying to set Peak loudness to -10 LUFS.
      --jay
        • 46164
        Add the DSP Effect 'ReplayGain' and click the advanced button.
        Do you want the gain to be written to ID Tags, or the audio to be altered in volume?
        • JayNYC
          • Feb 2008
          • 63
          I'd like the audio to be (permanently) altered in volume.
            • 46164
            Then use the DSP Effect 'ReplayGain' first, then re-run the batch with 'Replaygain apply'
            • JayNYC
              • Feb 2008
              • 63
              Hi Spoon -- just want to triple confirm something. I am looking to adjust PEAK to be -10 LUFS, *not* average. My understanding of EBUR128 is that it scans an audio track and decides on an average. I want to "look at the track's audio, and set the loudest part of the track to be -10 LUFS, and then everything else is relative below that"
              thanks.
                • 46164
                Use the volume normalize DSP, and set the peak to peak option and set the desired volume to -10 dB
                • schmidj
                  • Nov 2013
                  • 598
                  Jay, I'm a little curious as to why? Setting the peak to -10 dBFS (can't be LUFS, that by definition is an average), will result in many cases in a very low level track. Also, if you are listening to a collection of tracks, the levels to your ear will be all over the place, depending on what processing the track had before you adjust it. Your setting is not a particularly "consumer friendly" one.
