How to set up CLI Encoder for MP3HD?
  • FLAC 1
    • 22
    Now i know mp3Hd is maybe a dead format but i still got a Samsung music player that can reads it.
    And on my computer winamp doesnt have problems with it anyway.
    I got the encoder and decoder in exe and i need to know how to set up the command line in CLI encoder. Any help would be nice !
    To me MP3 is still king because its supported everywhere so sadly Technicolor stopped developing it because to me this is really a good codec.
    Re: How to set up CLI Encoder for MP3HD?
    If your samsung supports AAC you would be better using that (m4a AAC).
    • FLAC 1
      • 22
      Yes but with my dre beats headphones i love to listen to lossless more..
        If it is the YP-H1, then it supports FLAC, which would be better.
        • FLAC 1
          • 22
          Ok that's maybe true but i just wanted to test some mp3hd files i had a small utility tool to convert wavs to them but i cant find it anymore. Its indeed for the ice touch. Is it possible to set it up in CLI encoder or is that impossible?
          • dbfan
            • Jan 2011
            • 937
            Lossless is lossless, flac would give identical output to mp3hd, which was abandoned years ago
            • Lynx_TWO
              • Aug 2009
              • 85
              Yes, it is probably a dead format... The only good thing is it is backwards compatible with any normal MP3 player, but again, the benefit is you wouldn't have to have a lossy copy and a loss-less copy all at the same time...
              To the original poster, if you want more info, try here: http://forum.doom9.org/showthread.php?t=145768. Post a dropbox link or something for the .exe and I can help you out with the CLI syntax for dBpoweramp...
              • FLAC 1
                • 22
                Ok nice man will upload tonight !
