Error when attempting to convert?
  • abe
    • May 2014
    • 8
    I have a .NET application where I am attempting to convert audio files to mp3. I have installed dBpoweramp Reference R15, on my machine and I included a reference to the DLL: C:\Program Files\dbpoweramp\dmcscriptting.dll in my project. This DLL shows as DMCSCRIPTINGLib in my references folder and has the following information in properties:
    Identity: {E0F7789A-88C0-450B-AD6C-A7EB6D227127}\1.0\0\tlbimp
    Embed Interop Types: False
    (and some others as well)
    In my application I am using the following lines to attempt to convert:
    Code:
                    DMCSCRIPTINGLib.Converter dMC = new DMCSCRIPTINGLib.ConverterClass();
                    dMC.Convert(OrigFilePath, OrigFileFolder + "\\" + NewFileName, "mp3 (Lame)", "-b=128", "");
    When I hit the first line I get the following error:
    Retrieving the COM class factory for component with CLSID {1C2E0932-61B5-4EAB-A832-06EE6564047D} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
    Any idea why this would be happening? Suggestions on how to fix?
    • 44044
    Re: Error when attempting to convert?
    Does the example .vbs script work?
    • abe
      • May 2014
      • 8
      Hrrm, where would I find the example script?
      • abe
        • May 2014
        • 8
        I looked around in:
        But there doesn't appear to be any vbs scripts in there. Should I be looking somewhere else?
          • 44044
          On this page:
          • abe
            • May 2014
            • 8
            Ok, when I run that I get a bunch of popup windows that display information, but the file that I plugged in to be converted to MP3 does not get converted. It isn't throwing an error or anything, but I wouldn't say it's working. Does that answer your question?
              • 44044
              What does the popup windows say? if it shows the codec lists and codec settings then the com object is working as should.
              • abe
                • May 2014
                • 8
                I get a number of popups with the heading: "Codes installed" that contain the various codecs.
                Then an application window comes up that says "mp3(Lame) Compression Settings". It has a few radio buttons and a slider bar.
                When I click OK on that window a popup is displayed that has the heading "Returned Compression CLI" and says "-b 128".
                When I click OK on that window a final popup is displayed with the heading "Returned Audio Properties", but this popup is blank.
                Does that make sense?
                • dbfan
                  • Jan 2011
                  • 937
                  The com object is all working as should because each of those pop ups is supplied through the com object.
                  • abe
                    • May 2014
                    • 8
                    Interesting, so what could be the cause of the error that I am getting?
                      • 44044
                      Try:
                      I developed a Windows service using C#.NET to generate PDF report. To generate PDF file I am using a third party dll. The application is running in my Windows XP platform. When I deployed the servi...
                      • abe
                        • May 2014
                        • 8
                        Yeah, I tried all of the solutions I found on StackOverflow before I came here, but to no avail. Any other ideas?
                          • 44044
                          Just tried myself, had exactly the same error as yours, but when I go Properties >> Platform Target >> Any CPU
                          then it runs as should.
