Bug: .ReadIDTagElementValue and .AudioProperties give wrong rating on WMA
  • chrisjj
    • Nov 2008
    • 300
    e.g.
    * with WM/SharedUserRating = 0, .ReadIDTagElementValue reports 2 and .AudioProperties reports 1
    * with WM/SharedUserRating = 128 .ReadIDTagElementValue reports 10 and .AudioProperties reports 5
    * with WM/SharedUserRating = 255, .ReadIDTagElementValue reports 10 and .AudioProperties reports 5
    dbScripting.DLL 13.3.0.2
    Demo vbscript
    '' DMC Rating bug
    filename= "tempratingset.wma"
    r = 0
    dMC.WriteIDTag filename,"Rating",r
    WScript.StdOut.Write("Setting rating to "&r&vbCrLf)
    For each e in Split(dMC.AudioProperties(filename) ,VbCr)
    if Instr(e,"Rating :")<>0 then WScript.StdOut.Write(".AudioProps says: "&e&vbCrLf) ' for 0 reports 1!
    next
    For i = 0 To 10000
    keyvalue = dMC.ReadIDTagElementValue(filename, i)
    If Instr(keyvalue,"Rating:")<>0 then
    WScript.StdOut.Write(".ReadIDTagElementValue says "&keyvalue&VbCrLf) '' for 0 reports 2!
    exit For
    end if
    Next
    Re: Bug: .ReadIDTagElementValue and .AudioProperties give wrong rating on WMA
    Our tag reader has to map the tag values to a 0-10 range so they can go to other codecs, so the ratings are approximations for WMA.
    • chrisjj
      • Nov 2008
      • 300
      Thanks. Is WM/SharedUserRating the only property not reported faithfully?
        Perhaps
        • chrisjj
          • Nov 2008
          • 300
          If anyone has any details about the extent of this function's false reporting of property values, please do say. Thanks.
