Music Converter parameters
  • ignite
    • Apr 2011
    Well, maybe this question looks wear, and probably it is. Anyway, i already know the CLi for CoreCOnverter. But I use Directory Opus, and one thing that I love from this program is the ability of hide right context menu entries, and even create your own context menu (icons included). So I was wondering, there are parameters for the MusicConverter.exe. I mean, i see that sometimes use the -list_to_conv="Example.tmp", or something like this, in order to send certain files to the Music Converter, like in the context menu.
    • 45851
    Re: Music Converter parameters
    -list_to_conv cannot be used externally from dBpoweramp.
    • ignite
      • Apr 2011
      OK, so...
      What would be work?
        • 45851
        You cannot send anything to musicconverter, only coreconverter.
