uPlayer COM problems
  • Nuwanda
    • Jan 2010
    Hi, my first post
    I've downloaded the uPlayer.exe and installed it. The uPlayerCOMObj.dll (v1.0.0.1) shows up fine but when I try to add it as a reference to my Visual C*blooper* 2008 project I get an error that it's not a valid assembly.
    Any suggestions?
    Re: uPlayer COM problems
    Try from VB Scripting as a quick test.
    • Nuwanda
      • Jan 2010
      Thanks, Spoon.
      When I run this vbs in the dbpoweramp install dir...
      Code:
      ' create shell object
      Set WshShell = CreateObject("WScript.Shell")
      ' Create uPlayer Object
      Set uPlayer = CreateObject("uPlayer.uPlayerdB")
      ...I get this error:
        Try uninstalling and reinstalling uplayer, also what Windows version do you have?
