ActiveX component can't create object: 'dmcScripting.Converter'
  • Jeff Flowerday
    • Mar 2008
    • 105
    Error code: 800A01AD
    I'm running Vista x64 and I've unregistered the dll and reregistered, still no go.
    Any ideas?
  • Jeff Flowerday
    • Mar 2008
    • 105
    Re: ActiveX component can't create object: 'dmcScripting.Converter'
    I'm running R13 and I've also tried uninstalling and reinstalling.
    • Jeff Flowerday
      • Mar 2008
      • 105
      I quickly installed R13 on my 32 bit vista machine and it works fine there.
      • Jeff Flowerday
        • Mar 2008
        • 105
        Does the scripting not work with WMA files?
        get_AudioProperties returns an empty string
        get_ReadIDTagElementValue return an empty string for index 0
        ReadIDTag return empty element and value for index 0
        Or am I missing something?
          Do you have the WMA codec installed into dMC?
          • Jeff Flowerday
            • Mar 2008
            • 105
            Yes
              What language are you using? Have you looked at the code examples?
              • Jeff Flowerday
                • Mar 2008
                • 105
                I've tried both vbscript using ReadIDTagElementValue
                For i = 0 To 10000
                Dim ElementValue
                ElementValue = dMC.ReadIDTagElementValue("C:\Users\FlowerdayJ\Mus ic\Steve Morse\Major Impacts\01 Derailleur.wma", i)
                If ElementValue = "" Then Exit For
                Call WshShell.Popup(ElementValue, , "Read Tag", 0)
                Next
                I've also tried C# using ReadIDTag and get the same results.
                Nothing ever returns from index 0.
                • Jeff Flowerday
                  • Mar 2008
                  • 105
                  Ok a reboot got it reading the tags on my 32 vista machine. Still need to get it going on my 64 bit vista machine.
                  Any ideas?
                    • 45829
                    I don't think scripting will work in 64 bit.
                    • Jeff Flowerday
                      • Mar 2008
                      • 105
                      If you mean DMCScripting, are there any plans to get it working?
                        Try running your script, but prefacing it with "C:\WINDOWS\SysWOW64\wscript.exe". That way it uses the 32-bit script engine instead of the 64-bit.
                        • Jeff Flowerday
                          • Mar 2008
                          • 105
                          I don't want to use script. I prefer C# and it doesn't work their either.
                            Probably because the libraries in the system are 64-bit and want 64-bit objects, but the dMC scripting object is 32-bit and so cannot create it.
                            I just suggested running with the command-line above to see if the problem was it was wanting a 64-bit COM object.
                              • 45829
                              The code for scripting is still compiled in VC++ v6, which cannot compile 64 bit.
