Including ReplayGain with scripted OGG conversion
  • xja
    • Jan 2004
    Using DMCSCRIPTINGLib, I am able to script an OGG conversion successfully, but is there a way to specify that I would also like ReplayGain action applied (ie, calculated and written to the tag)? I tried setting it up ReplayGain as action under OGG conversion in the DMC application, hoping then that this default would be used when I scripted the OGG conversion, but ReplayGain action was not applied when I then performed the scripted conversion.
    FYI, I am using C#.
    Thanks!
    • 46164
    Re: Including ReplayGain with scripted OGG conversion
    When converting to ogg, add in the replay gain dsp effect (you have to suply the DSP command line on the script).
