Problem with DSP combination : Grabber + Fade
  • touff-ray
    • Apr 2007
    • 36
    Hi all,
    I would like to make extracts with some nice fading effects. So, I use the Grabber DSP to grab 30 seconds from my song, and then I use the Fade DSP to add the fading effects.
    Here is the command line corresponding to the DSP part that I use :
    Code:
    -dspeffect1="Grabber=-lengthms={qt}30000{qt} -position={qt}30000{qt}" -dspeffect2="Fade=-inlengthms={qt}4000{qt} -outlengthms={qt}3000{qt}"
    (please note that my extract begins at 30s, not at 0s)
    The result is a 30s file, with a fade-in, but no fade-out !
    I have tried this combination with the graphical interface of dbPowerAmp, with the same result.
    So, is this behaviour expected, or am I missing something ?
  • touff-ray
    • Apr 2007
    • 36
    Re: Problem with DSP combination : Grabber + Fade
    Anyone ? :s
    Or maybe could somebody else check on his own computer...
      • 46164
      Add the 'Non Live' DSP effect and it will work.
      • touff-ray
        • Apr 2007
        • 36
        Thank you.
        However, now I have a different problem. This solution works with small files (1 minute) but not with bigger files (4 minutes). I am getting the same error as in there : http://forum.dbpoweramp.com/showthread.php?p=62956
        (I am using R12.3 and DSP R2)
          • 46164
          Reinstall the DSP Effects, there was an update to them which should have fixed that, also try R12.4.
          • touff-ray
            • Apr 2007
            • 36
            Even with the latest DSP Effects (from http://www.dbpoweramp.com/dbpoweramp-dsp.htm) and R12.4, I am getting the error :(
              • 46164
              Start >> Run and type
              %tmp%
              does this drive have plenty of free space?
              • touff-ray
                • Apr 2007
                • 36
                Yes of course, at least 8Gb available.
                  I've taken to trying this myself.
                  Same problems:
                  1. fade won't apply to the end of a grabbed sample, with the possible exception of a sample taken from the end of the track;
                  2. Using the Force Non-Live dsp with grabber and fade dsps results in error suggesting disk is full even though it is not (at least not as far as I know-temp folder shows as having a little under 5 gigs, my drive with dMC r12.4 has 89 gb free space (although my Windows drive only has 3.56 gb free).
                  What will work is applying the effects separately (first to grab the sample and then to do the fade).
                  Bill
                  • touff-ray
                    • Apr 2007
                    • 36
                    Thanks for trying this as well
                    Applying the effects separately is not an option for me, that is why I am so persistent :D
                      • 46164
                      Will mark as a bug to look at.
                        • 46164
                        Now fixed:
                        http://forum.dbpoweramp.com/showthread.php?t=15297
                        • axe
                          • Jun 2008
                          Hi
                          I am brand new here, just downloaded dBpoweramp and DSP Effects. I am using command line only and want to do what is described above. It all works except I get the same problem of end not fading. You mention to use Force Non Live but I can't work out how/where to use in command line. Is it a seperate effect or something you add to each effect. what I have so far is:
                          coreconverter.exe -infile="c:\Sinkor.mp3" -outfile="c:\test.mp3" -convert_to="mp3 (Lame)" -dspeffect1="Grabber=-lengthms={qt}30000{qt} -position={qt}100000{qt}" -dspeffect2="Fade=-inlengthms={qt}4000{qt} -outlengthms={qt}8000{qt}"
                          btw this is a great app
                          On a side note: I will be using in an asp.net c# web app and calling exe from code - is this the only way to do it or is there an api or can I build something to provide an api. I'm quite happy calling the exe I'm just curious and havn't had a lot of time looking at all the features of this app.
                          Axe
                            • 46164
                            The force non live is a seperate effect, so you would add it as -dspeffect3="Force Non-Live="
                            • axe
                              • Jun 2008
                              Thankyou.
                              Will try as soon as I get home.
